BFL13
Jun 13, 2019Explorer II
S Davis wrote:
I think at this point I will go with two 8Ds, that way I can achieve the magic 20% charging with the Outbacks 125amp charger. The Outback inverters can be stacked so in the future if I need more power I will add another inverter and two more 8Ds.
Just be sure that your shore power can deliver the input to run the 125 amps, or else half that, so you can do one 8D at a time, if not both.
I can't run my 75 amper at home at 75 amps on the long extension cord to a 15a receptacle. It hangs in there at about 65 amps due to low voltage input. Some folks do a special RV "outlet" at home, so it can do what's needed.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
