myredracer's avatar
myredracer
Explorer II
Jun 19, 2015
On repairing cabinet door hinge screw holes
We're camping for a couple of weeks with friends of ours. The bought a Keystone TT about 1 1/2 years ago and the cabinet work is atrocious. Just about all the cabinet doors are terribly misaligned, falling out or flying open in transit. A project for one of the days when the girls are out at the mall is to fix it all up.
I know this topic has been discussed in the past but I'm wondering what to do in this specific case. My plan was to use the 'ol toothpick and wood glue method to fill the old holes. Some of the screw holes for the hinges need to be moved only about 1/16". If I plug the holes with toothpicks and glue and drill an new adjacent hole, will this be strong enough? Maybe epoxy glue would be better. Or longer screws this time? I'm hoping the holes won't have to move much so that you won't see the old patched holes. Many of the roller catches have to be re-mounted but they won't be seen when doors are closed.
FWIW, this issue doesn't seem to be uncommon with Keystone. Saw the same thing on brand new units at the last RV show and have read about others having the same problem. Hard to believe they let such sloppy workmanship out the door, but they do and folks still buy them...
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
