Gjac
Apr 15, 2021Explorer III
Ltrip said: Re: using the external charger. When I hook that up to the new 12v battery, I expect the battery monitor to show > 12.7v. It does not. The battery monitor was at 12.3 this am and did not change when I hooked up the external charger.
Sounds like your battery monitor is not working because it is disconnected somehow. Again check voltage with a multimeter at the pos and neg terminals of the battery when using your portable charger it should read 13 plus volts. Let us know what it reads. Do you have a multimeter?
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
