ddisp1
Apr 03, 2014Explorer
ONAN - LP Liquid Genset not starting
I've searched through RV.NET, but haven't had success looking for information about my generator problem. I have a ~2004 ONAN 5.5HGJAB1271A Liquid Propane generator that won't start.
My suspicion is that the LP Liquid to Gas Converter is clogged up, as the generator (and motor home) were stored without prep for several years. I don't think the genset has more than 100 hours, but I'd have to check. (assuming it has an hour meter)
I've contacted the Cummins Onan repair shop in my area and they have limited resources and only one technician.
I'm pretty handy (just replaced both Rooftop AC's :) ) and would like to consider digging into this myself, but am a little nervous...
Any ideas about:
* Is the "LP Converter" issue a common one (or am I confused)
* Are there easy ways to check for this or other common issues?
* Will the "error codes" generated by the genset cover things like this and will they generate a code if it won't start?
* Am I biting off more than I can chew? :)
Thanks for your help. I've been reading RV.NET for years, but haven't bothered to get an account. Looks like great information with a great group and I'll try to make up for being a Lurker. :)
David
Any ideas about:
David
