MEXICOWANDERER
Dec 08, 2020Explorer
The Onans use a bunch of latching relays. You will need wiring diagrams from ONAN not Cummins. I take it this is a diesel.
Start Run circuit
Safety shutdown circuit
Both are needed.
Onan is famous for using 3 colors of wiring and ID numbers on the wire.
The plastic rings around wires are current sensors. Do not remove. Anything with a plug and socket should be unplugged and doused with Caig DeOxit D100 then replugged.
You need a ganged 240 breaker near the machine.
The generator must be enclosed with ventilation. It cannot survive getting wet.
Long term storage plug the exhaust with a rag. I strongly recommend a RAcor fuel water filter. If the unit has glow plugs I also recommend a push button over ride if temps approach 0°F.
Keep the unit high enough off the ground to make oil changes easy.
Start Run circuit
Both are needed.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 29, 2026
