pirlbeck's avatar
pirlbeck
Onan 2500 KVD problems
New to me 2009 Lance 845 with an Onan RV QG 2500LP generator with 40 hours total run time starts very hard and runs rough. It also appears to have an engine oil leak. When we looked at this unit the owner said that he did not remember when the generator was last run, but after a lot of cranking he was able to get it to fire and keep running. I did notice at that time that it was not running smooth, but I thought it may improve with some run time. After I got the camper home I tried to get the generator running and while it finally fired after a lot of cranking, it would not stay running when the start switch was released. It acted the same when trying to start it from the remote panel and from the control panel on the generator itself.
Last night I pulled the generator out of the camper and tonight I hooked propane and a battery to it and fired it up. It started pretty quick and it kept running after the start switch was released. I am not sure what changed that it will now keep running.
I do now know that the rough running is being caused by too rich of fuel mixture because it will smooth out and run very smooth if I close the fuel tank valve until it is almost closed. The air filter looks like new and running it with no air filter makes no difference. I have it hooked up to a tank with a brand new regulator that I tested the pressure on with a manometer and while it is a little high at 13WC, it runs the very same as it did with the camper tanks and regulator. If this was a gas powered unit I would be looking for either a carb adjustment or a carb problem, but with propane I don't know. Anyone have any thoughts on this?
Also there is an oil leak somewhere on the bottom side of the engine.....any common areas to leak on these?
If it matters the Model number is 2.5KVD2089B Spec-B and the sn is D090241978
Sorry about the length of this.
Thanks!
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jun 23, 2024
