opnspaces
Jul 06, 2019Navigator II
by your description I'm guessing it's a loose or burned connection somewhere in line with the start switch. Start at the battery and make sure everything is tight.
Do you have a multimeter that you can use to see if you are getting battery power at the fuse or on either side of the switch?
Having RV issues? Connect with others who have been in your shoes.24,212 PostsLatest Activity: Mar 12, 2025
