TEXAS
May 15, 2014Explorer
Yes you can change the oil and filter and spark plug. Doesn't have an oil filter just a gas filter. Nothing dangerous about doing the routine service. That model may have a low oil level sensor causing a false shutdown. Onan stopped using them because of the problems they caused. Look for a wire under the engine going to the oil pan.
The other problem could be loss of AC voltage.If you don't have the service manual. Go to Smokstak Onan section. Post an email address and you will get one. Supply full model and serial number
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
