guy48065's avatar
guy48065
Onan 3.6 won't crank
A friend asked me to help troubleshoot his RV generator.
It will not crank using the onboard start switch or the remote on the switch panel.
Using a meter I verified there is solid battery voltage at the starter solenoid. There is one small white wire on that lug that I assume powers the control & start circuits.
Using a meter I determined which terminal on the solenoid needs switched 12v and I jumped it and the genny cranked.
Anyone have a wiring diagram of the control circuit?
I'm hoping there's a fuse or an interlock somewhere I haven't discovered.
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
