MEXICOWANDERER
May 24, 2016Explorer
http://www.ebay.com/bhp/onan-generator-carburetor
Dual fuel conversions are problematic. Use a dedicated single fuel (LPG) carburetor.
Prepare for significantly higher engine operating temperatures, noticeable reduction in engine horsepower (= Kw) and greater weeping of lube oil from seals and gaskets.
LPG is wonderful for short duration start and stop generator operation. Far less spark plug fouling, oil contamination, and fuel deterioration when left unattended for months (or years) at a time.
But there are other drawbacks: Limited fuel capacity, need to drive entire rig to LPG filler station if tank is permanently mounted, and fewer mechanics to lend assistance if you need it.
Only you can weigh the pluses and minuses and decide if LPG generation is for you. Don't let anyone verbally strong arm you either way.
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: Apr 05, 2017
