Chum_lee
Oct 23, 2017Explorer
darsben1 wrote:
Is the altitude adjustment on the bottom of the carb bowl set to the approximate altitude
Lean mixture.
Yep, that's the first thing to check. If you are running the genny at close to sea level while adjusted for high altitude operation (lean) that would do it. If your main jet is plugged, or, you have a vacuum leak in the intake, that would do it too, but check the altitude adjustment first since it's easy.
Chum lee
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 17, 2026
