- drsteveExplorer
maryjoey wrote:
It is my very first time posting on any forum ever. I don’t know how to move it or rename it
Your post has already been moved to the Tech Issues forum by the moderator. Only a moderator can move a post. - maryjoeyExplorerIt is my very first time posting on any forum ever. I don’t know how to move it or rename it
- drsteveExplorer
joebedford wrote:
drsteve wrote:
That question should not be asked here, rather Forum Technical Support1492 wrote:
? Did you miss the FTS "Announcement : READ BEFORE POSTING HERE"?- Forum Technical Support (FTS) is reserved for questions related to the use of the Open Roads Forum website,
member profile and photo testing, and for reporting account issues. Please avoid using FTS for RV related questions.
Instead, select the Sub-Forum which corresponds to the subject of your topic.
Thank-you!
Moved from FORUM TECHNICAL SUPPORT
Why don't you guys rename the Forum Technical Support subforum and/or change the description so people realize not to ask questions about their rig problems there?
Maybe the mod will move it :) - turbojimmyExplorer
maryjoey wrote:
2013 eclipse attitude
No points then. I would start with plugs. - maryjoeyExplorer2013 eclipse attitude
maryjoey wrote:
I didn’t change anything on it or go anywhere with it. It was fine the last few times I started it monthly
Need to know how old it is. If nothing has changed I would suspect something ignition related. If it's old enough to have points, I'd start there. - maryjoeyExplorerI didn’t change anything on it or go anywhere with it. It was fine the last few times I started it monthly
- joebedfordNomad III
Thank-you!
Why don't you guys rename the Forum Technical Support subforum and/or change the description so people realize not to ask questions about their rig problems there? - grizzzmanExplorer
maryjoey wrote:
in trying to figure out why its bogging down and making popping noises, please help
I have had a broken valve spring do that. It had a wapping 150
Hours on it when it failed.
good luck - road-runnerExplorer III
drsteve wrote:
That's a great suggestion. Maybe something like "Web site software technical support"?
Having RV issues? Connect with others who have been in your shoes.24,352 PostsLatest Activity: Jan 21, 2026
