SJ-Chris
Jul 22, 2021Explorer II
gbopp wrote:
Did you try spraying starter fluid into the intake while it's cranking? If it starts and runs a few seconds you probably have a fuel delivery problem.
Thanks for the suggestion. Please help me understand how to implement your suggestion...
I assume the "intake" (carb?) is basically where the air filter is sitting, right? So would I remove the air filter and then spray starter fluid in there while cranking? The way the air filter housing is situated, I cannot see inside there so that will make it a bit challenging.
I guess something like this would work?
https://www.walmart.com/ip/STA-BIL-Starting-Fluid-22004/764691516?wmlspartner=wlpa&selectedSellerId=0&wl13=5766&adid=22222222420449455996&wmlspartner=wmtlabs&wl0=&wl1=g&wl2=c&wl3=501107745824&wl4=pla-293946777986&wl5=9032145&wl6=&wl7=&wl8=&wl9=pla&wl10=8175035&wl11=local&wl12=764691516&wl13=5766&veh=sem_LIA&gclid=CjwKCAjwruSHBhAtEiwA_qCppnLIDPa5g5DilwKFOS9sPvo0Jw7f8NKKMvDtZkLdTiH-NhoFiSPzRhoCEYsQAvD_BwE&gclsrc=aw.ds
Does it usually come with some sort of straw so that I could get it in closer to where the carb is (...the air filter housing is probably 4-5 inches deep).
I'll give it a shot. Thanks!
Any other suggestions?
-Chris
