Grit_dog
Jul 23, 2021Trailblazer
It appears you have spark, although I’d expect yellow/blue spark.
Also has to if it backfired and lit the ether on fire.
Disconnect fuel line from carb. Prime the pump. Do you hear the fuel pump and are you getting fuel?
Mostly likely cause of well maintained runs fine suddenly not running is the fuel pump. You can see the fuel pump in the generator. It’s in line in the fuel line coming from the tank.
Quick fix, go buy a little electric fuel pump for carburetor from the parts store. They’re relatively universal and about $30-40. If your fuel pump isn’t pumping.
Something else could be blocking fuel from the tank. Not super likely but try sucking fuel through either by mouth with an extension of clear hose so you see before swallowing
Lol. Or a vacuum pump like for changing oil.
