Kpackpackkelley
Sep 10, 2014Explorer II
How many hours on the unit ? The experts need the full model and spec letter to know which gen you have. Yes the piston can get stuck on a ridge at top.
The valves can be to tight. Loose connections , battery , many things to look at.
The reason I ask the hours is because a friend of mine had a 4 ky locked up it had about 1800 hrs on it. This one had formed a ridge at the top of the cylinder so the piston was stuck on it. Hit it with a wood block and hammer and it popped loose. The gen had been run low on oil so we called it doa and not put any money in it.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 26, 2026
