Kpackpackkelley
Sep 10, 2014Explorer II
dclarke618 wrote:I don't know your trailer but you have to take the cover off. If its in a pretty tight compartment you will have to take the gen out to get to the starter.
For a 1998 Winnebago Adventurer do you have to drop the generator in order to remove the main cover and replace the starter?
How much room is there on the sides that's where the torx head screws are that hold the cover on two on each side. Then you would have to have room at the top of compartment to get the cover high enough to get it off .
Do you have a multimeter and know to use it a little bit ?
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 26, 2026
