ajriding
Jan 23, 2021Explorer II
I have same gen and just replaced the carb.
Can you explain exactly which bolt is the issue? The one on top at paper towel, or the one on the bottom that has threads poking out of intake piece, but no bolt head?
If the lower one, then maybe you can work a nut onto the threads instead of trying to put new bolt through it. You will have to carefully clean the end of the bolt or just be really lucky that a nut will thread on. DO NOT cross-thread it though.
If I remember maybe that lower bolt was threaded in from the right side, and the one on the back side was from the left, as you can see the bolt head, but I am probably mistaken..
I assume though, that it is the top, as the lower part does not need to be messed with for a simple carb change. You should e able to just extract any broken pieces. You could literally make it work with a c-clam to hold the carb on, this just needs to be airtight so intake is not sucking air in after the carb.
