americanrascal's avatar
Dec 15, 2015
Onan 4000 KY Clicking sound?
Our rig is about 2 yrs old with a 4000KY Onan gen set. It has about 160 hrs on it and runs smooth and well. It is used and cycled regularly (about every 2 weeks for 1-2 hours) under load.
But of late its started a loud and noticeable intermittent clicking sound. I note no deterioration in its running, it runs smooth, no error codes, starts relatively easily.
I pulled the cover to check for rubbing on the cowling but the clicking continues.
Any ideas what to suspect? My mind is thinking its an impending fuel pump issue?
  • I would unplug the pump. With the unit off. Run a jumper wire over to the pump. If it comes on very loud probably bad.It should pulse until it builds up pressure and then slow down.
  • Thanks guys. The lack of regularity and the loudness then would tell me not the hour meter. Guess I might better order a new fuel pump to have on hand??
  • americanrascal wrote:
    Thanks for the follow up beemerphile1.
    Mine sounds rather loud and irregular. Is the sound you hear like that? Seems to have appeared recently- last 10 hours or so?
    Nah, the meter clicks at regular intervals but mine is loud.
  • DrewE's avatar
    DrewE
    Explorer III
    Hour meter clicks are very regular and shouldn't be too loud. I think mine are once every 3.6 seconds (i.e. every 1/100 of an hour). Presumably it's from the little escapement doohicky that drives the reels of the meter.
  • Thanks for the follow up beemerphile1.
