JaxDad
Apr 09, 2017Explorer III
Those units use externally excited coils, so voltage out is in direct relationship to the voltage input.
If you give it 12 volts, you will get 120 volts. If however you only have 9 volts in you will only get 90 volts out. Since that is an unsafe output the Onan will shut down for safety.
Check & clean all your connections, including the grounds.
All it takes is a funky connection to cause a momentary drop in voltage and you will see exactly your symptoms.
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
