Artum_Snowbird's avatar
Mar 04, 2018
Onan 4000 won't start...again
A month or so ago I posted about my generator not starting. I thought it was the starting solenoid. I did buy a new one, installed it, and it's exactly the same problem still.
The generator clicks, but will not turn over. This is a two year old unit with only 80 hours on it.
So, I took a measurement of the voltage into the starting solenoid. On shore power 14 volts. When I engage the start button, full voltage goes to the new start solenoid. Same clicking sound. Output of the start solenoid is still 2.7 volts.
Somehow, voltage is being sucked down. Flywheel turns easily. I used the 9/16 wrench on the fan, no problem there. No whirring sounds from the starter at all.
I put jumper cables onto the unit ground, and the positive terminal of the start solenoid. No change.
It does not turn over at all.
Any suggestions before I have to pull the unit out and go directly to the starter?
Having RV issues? Connect with others who have been in your shoes.24,330 PostsLatest Activity: Oct 30, 2025
