SAR_Tracker
Apr 27, 2015Explorer
As others have said:
1 - check the gas in the main tank.
2 - hand over hand on the fuel line from main tank to carburetor. I'll bet you find another filter somewhere.
If the above turns out fine, then run a line from the pump/filter on the generator to a can of known good gas. If it runs longer than 4 minutes, the problem is in the line to the main tank. There may even be a clogged filter INSIDE the tank on the pickup tube for the generator line.
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: May 19, 2026
