Chum_lee
Jul 02, 2018Explorer
MEXICOWANDERER wrote:
Onan Generator Air Cooled
Small aircraft engine Air cooled
Generator limited RPM
Aircraft limited RPM
Generator sees wide temperature range
Aircraft sees wide temperature range
Generator can see much hotter metal temps
Aircraft can see much hotter metal temps
The big difference is ASH content of the oil
Onan used to make an uproar about ash content with Onan engines using LPG
Question: Is the newer API service J or service K oils as low in ash as aircraft oil? If there was no difference then why does Lycoming insist on low ash engine oil. This area should be explored. There is something to it.
Comparing the similarities of Onan air cooled genny oil to aircraft piston engine oil is interesting, but, its where they differ that's important. (and WILL KILL YOU) One: Most aircraft piston engines still use 100LL avgas which contains tetraethyl lead (octane enhancement) and methylene/ethylene dibromide. (scavenging agent) Onan gennys use 87 octane unleaded gas. Two: Aircraft piston engines require oil changes every 50 hours compared to 150 for the gennys. Three: Aircraft piston engines are designed to burn oil and oil consumption is expected.
Aircraft engines require ashless oil because when metal containing dispersants were first used, there were an excessive number of fatal engine failures due to clogged oil systems, detonation, and insoluble deposits in the ring land areas leading to engine failure. (and more) These failures were attributed to excessive deposits from oil burning.
The failures were not attributed to: "My mommy told me that . . ., My mechanic said that . . ., My brother in law said that . . ., I read on the internet that . . . ., it goes on forever. They were attributed to actual field research by people who KNOW what they are doing and have the overwhelming science to support it. What a novel idea!
Ashless Dispersant oils do not contain ash. They minimize ash generation when burned in the combustion environment. Kind of like a log on a campfire does not contain ash. Ash forms as a chemical reaction in the fire pit as the wood burns.
Suffice to say: Follow the oil change recommendations in your owners manual regarding oil for your Onan genny, and you'll be fine. And MEX, you've got to cut out those afternoon naps. API SN has been current for a few years now and is about to be updated. Newer automotive oils (API SN) do generate less ash when burning due to changes in the dispersant and the extreme pressure wear additive chemistry. In the automotive industry they were mainly changed to improve catalytic converter efficiency.
See: http://www.pqiamerica.com/apiserviceclass.htm
Chum lee
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jan 17, 2025
