64thunderbolt
Dec 18, 2014Explorer II
If you have to hold the choke open to keep it running the carb needs cleaned. Been there. Remove it take it apart. Put it in a coffee can cover with seafoam and let soak for a few days. Blow it out with compressed air and it should work fine. Did this on a spare carb I had and it has been running fine on my friends gen for a yr now. It was doing the same thing before I removed it. Seafoam is your friend. I use it every fillup. Best cleaner you can get. Better than $280 for a new carb.
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
