BruceMc
Jul 02, 2013Explorer III
Onan 4KY fuel pump replacement method?
Does anyone have a step by step process to replace the fuel pump on an Onan 4KY?
Upon testing my genny in the hot weather yesterday, it ran for about 10 minutes under load, then abruptly quit.
The fuel tank is within a gallon or two of being full, so it's not running out of gas.
After letting it cool down for 20-30 minutes, it restarted and ran fine for a while before I shut it down.
Today, we have another hot day (95°), so I thought I'd test it. It started fine, and after a few minutes, I loaded it with the rooftop air. It ran for about 10 minutes and quit again.
I pulled the cover thinking it would have some trouble codes, but alas, the red light was, well, not red at all.
Running the prime, it sounded real wimpy, very quiet. I pulled the fuel line at the carb, no gas. I aimed it at a bucket, then pushed prime. Wimpy sound, NO fuel.
Again, after letting it cool for 20 minutes or so, I tried priming again - normal pump noise. The generator started with a bit of trouble, but of course, the float bowl was empty. Once the air was flushed, it ran fine again. I shut 'er down.
The filter was replaced about a year ago, and other than maintenance runs and about a half hour last summer, it hasn't seen much run time. I replaced the pump in the main fuel tank last winter, and the tank was surprisingly clean, so I'm ruling out the filter.
Onan part numbers: Pump #149-2311-02, filter #1492457
Thanks in advance!
--Bruce.
Thanks in advance!
--Bruce.
