rvten
Jul 01, 2013Explorer
I am having a similar problem.
Changed fuel filter, spark plug air filter and changed the oil.
Gen runs with or without a load for about 20 min. Starts to surge a little than shuts down. I get a 36 code.
I have flushed carb out with carb cleaner. Added Sea Foam to MH gas tank.
Checked fuel line. Drained carb using the drain screw outlet. I get clean gas
I like the old carbs that had adjustment screws on them. I see non on this one. Except for governor. I show 120 volts and 60/62 hertz. I see the fuel pump. But not the 2 screws that hold it in place. What a PITA to work on.
