sdetweil
Apr 17, 2015Explorer
UKPETE wrote:
Many thanks, and the 2 white and 1 brown can go on any of the 3 connectors at the bottom. Or does the brown have to go on one specific connector. As the other side has all white wires.
Many thanks, Peter
as you are colorblind, any chance that 'brown' would be green (it should be)..
that lug bar is all the same, so any connection point should be the same.
the wiring diagram shows all three non-load wires going to the same place.. on mine they are connected to the base plate with a bolt. yours has connectors, but same design/results.
