Team_Roper_Heel's avatar
Jan 02, 2020
ONAN 5500 @ high elevations
My wife and I will be heading west in September. Overnighting around 9000'. What do I need to address to insure optimum performance. We currently live around 1,500'. Thanks for the help.
  • Thank y,all for the information. We are just overnighting in the Rockies on the way west bound to Yosemite. I was just curious about having to adjust the carb. Thanks again for the help
  • To clarify, the adjustment they are referring to is inside the cover of your 5500 and is clearly visible.
  • roam1 wrote:
    Turn the carb adjustment to 10,000 and enjoy,
    Yep! That's what it's for. Just don't forget to turn it back down to the proper altitude when appropriate. There is a danger of overheating/damaging the engine if you forget and don't.
    Chum lee
  • Turn the carb adjustment to 10,000 and enjoy,
  • What Ed said X2. I wouldn’t worry, not like you’re running the AC units. I don’t have issues running my 3k gen for microwave, etc. at that altitude.
    Mr Wizard is right, it can get cold that time of year but run your furnace and you’ll be fine.
    Mr Wizard-some of us are gluttons for punishment and spend the winter at 9k ft just to ski :).
  • I going to ask the question others are thinking
    Are you going skiing, are you a glutton for punishment
    Or maybe just a "dark sky" astronomer
    Why in the world overnight at that altitude and cold temperature
    Better keep the furnace on and the cabinet doors open
    Or be winterized
    I went thru Flagstaff Az in Nov one year (I think it was 1996) In my First class A
    AND THAT WAS COLDER than I wanted to be, and that is not as high as you want to do
    Sept in the Rockies ? At 9000ft is freaking COLD
    I FROZE my wavos at night at 7000ft in the Searres in July in a tent at 30°
  • At 9000 feet you more than likely won’t need A/C. An adequate solar system will provide you with good battery recharge capability...no need for the generator almost every day.
    Gasoline powered generators do have a carburetor altitude adjustment,,,if you have a gasser....
    Effects Of High Altitude And Extreme
    Temperatures
    If you travel at high altitudes or in extreme temperatures, your generator can lose power. In such lower-density air conditions, you can’t operate as many electrical devices as you could under normal operating conditions.
    Power decreases 3.5% for each 1,000 feet above an altitude of 500 feet. For example, to operate at 4,500 feet (4,000 feet above rated generator altitude) multiply 3.5% x 4 (4,000 ft) = 14% power loss. Then multiply .14 x your generator’s power rating: 4,000 watts x .14 = a loss of 560 watts at that altitude.
    Power decreases in extreme temperatures by 1% for each 10° F (5.5° C) above 85° F (29.4°C).
    NOTE: The carburetor on a non-EFI gasoline generator may require adjustment at high altitudes. (See your Operator’s Manual or your Cummins Onan Authorized RV Service and Parts Dealer.)
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
