185EZ
Aug 15, 2019Explorer
Look underneath the muffler
Probably a square 1/4" pipe plug
Remove it and run the gen
Could be a lean condition if the plug porcelain was white but you just changed plugs.
The tip was black so maybe it's more ignition related, wire, coil, circuit board etc.
Check your altitude adjustment
The fact you replaced carb and pump and filters points more to ignition or lack of.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
