twodownzero
Aug 16, 2019Explorer
MEXICOWANDERER wrote:
It points to a fuel starvation issue. Classic symptoms.
It's classic for a lean condition, generally caused by fuel starvation, but he could be sucking air around the throttle somehow as well. All air must pass through the carburetor or the fuel mixture will be wrong.
Verify proper compression, if ignition timing is adjustable check that, and if that is good, go back to focusing on fuel system issues or vacuum leaks.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
