Chum_lee
Aug 16, 2019Explorer
Chris Bryant wrote:
If it started suddenly, I would bet on a broken valve component- spring or rocker arm.
Yes, I've seen that (and/or a tight valve clearance) on 5.5, but IMO, it would happen all the time, even when cold. How does that explain this: "It began backfiring and then dying when a load was placed on it. . . . . . until it dies then gives an overheated exhaust code."
I'm assuming that later after cooling off, it runs (semi) normally when warming up and NOT under load. A compression check and a look at the valve train/clearance is in order. Interesting issue. This is a NEW generator!
Chum lee
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
