bounder39zman
Apr 09, 2018Explorer II
What is the model no. of your genset? Is it an HDKBA or B.?
The official word from ONAN and Kubota (engine manufacturer) on use of starting fluids is ABSOLUTELY NEVER! You can easily break piston ring lands with starting fluids. If your set cranks over, but will not start, you need to find and correct problem. As OP posted; check fuel level in tank, then maybe fuel filter and fuel pump. four months is not a very long time to set with diesel fuel. Any chance critters have gotten in set and chewed on some wiring? We see this a lot at my shop.
also, check for fault codes stored in control.
Are you getting any smoke (white or grey) from tailpipe when attempting to start? if so, then you are getting some fuel delivery, but perhaps glow plug system not working.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
