nas6car's avatar
nas6car
onan 5500 generator problems
generator driving me nuts. always well maintained, but now having issues. flash code not helping me. replaced fuel and filters and added seafoam to the tank. it will run for 10 minutes, sometimes up to 1 hour with smooth idle and then just shut off. it seems like something is getting hot and opening a contact. it will not start back up for about 15 minutes and then same thing. I don't think its a fuel pump or carb issue. seems more like coil or internal short. can anyone help me please. p.s. bought Honda 2000 backup genny for now seemed like cheaper fix.
  • Onan has problems with fuel pumps getting hot and shutting down. Had the same problem last week. Would run for 30 seconds to no longer than an hour. Replaced with low pressure generic fuel pump from napa for $50 and problem solved.
  • Post the dataplate model and serial number (or model and spec code at least). It's very hard to give you much info without knowing which Onan 5.5 KW you have.
    For most models, this will tell you if it's the coil - disconnect a plug wire, connect a spare plug, touch the plug base to the engine and press the start button, then release it. It should spark at least once. If it's sparking multiple times, then it's a gas or air problem. If it sparks only once, when you release the start button, the coil is working and it's something else.
    If no spark (for most Onans), it's the coil. To be sure, measure voltage at the coil. If you get 12V on then off and no spark, it's definitely the coil.
Having RV issues? Connect with others who have been in your shoes.24,354 PostsLatest Activity: Jan 24, 2026
