Jack_Kay's avatar
Jack_Kay
Onan 5500 Generator stops
We have a Onan 5500 generator in our rig that doesn't want to run more than about 10 minutes when we are driving. When parked, it runs until I shut it off. The unit only has about 28 hours which is not a lot, so the first owners didn't run it much. I changed the oil and filter the other day & thought that might help. I am able to restart after a few minutes, but it will still shut down when rolling down the road. I do have a full fuel tank & the altitude adjustment is set for sea level where we are now. I have the manual and I need to verify what code is blinking, but I don't understand what would be different about driving and sitting still. Fluids being tossed around? Any thoughts?
  • The code is 36 which seems unspecified stopping. Not much help. I parked too close to the pedistal to open the door to check the oil. Have to wait until I move now.
  • My 5500 Onan was doing about same thing. Has been several posts on issue. Mine threw code 36. Fuel pump was over heating. They replaced under warranty. So far runs ok. If it happens again I am going to move the fuel pump away from the generator a few feet and bolt it to the MH frame where it will get more cooling.
  • Double check the oil level once again. They have a switch to shut down when oil is low. Turning a corner will likely cause them to shut down when low alos...
Having RV issues? Connect with others who have been in your shoes.24,330 PostsLatest Activity: Oct 30, 2025
