allbrandauto wrote:
fuel pump fuel pump fuel pump been there done it not a hard job best way to check wait till it stops running pull cover off push down switch to prime you will here fuel pump clicking if not pull wire off fuel punp get 12 volt test light ground one end check wire you pulled off with other end while pushing prime switch down if test light lights its your problem I carry a extra fuel pump with me
I ordered fuel pump, fuel filter and air filter from Amazon. Should arrive today. I'll try to tackle it myself ... wish me luck.
