othertonka
Sep 23, 2013Explorer
First take the front cover off and find the START/STOP button, lower left corner. Note that the STOP button is also a PRIME button. Press and hold down the PRIME button and you should hear the fuel pump start to click. Let it prime until the clicking stops or at least slows down. While it is clicking locate the sound of the pump and you will find it underneath the left front corner of the gen set, clamped to a rubber fuel hose and will have a filter screwed into the pump.
Priming might also assist you in your hard starting problem.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: May 23, 2026
