JoeH
Sep 25, 2013Explorer III
OldF**t wrote:DavidM49 wrote:
I could hear the pump running while trying to prime the carb. It was like a hammer sound more than anything. That being said, I got nothing out of the fuel line when trying to prime the carb.
Well the next step would be pulling the hose off of the pump filter to see if fuel is available from the tank. The tank should be half full or greater as the generator fuel line pickup is not at the bottom of the tank. Also the line to the tank could be bad or have a leak which would cause the pump to suck air instead of fuel.
Yep-- common to have cracks and resultant air leaks in the tank to pump line.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: May 23, 2026
