Kpackpackkelley
Feb 23, 2014Explorer II
If you need the service manual I'll send it to you.
Could be a gasket leak letting to much air in so closing the ckoke cuts the air down. Tighten all screws and bolts up around carb and air housing head gaskets crank case breather or anything related. The manual has a the torque specs. Do not over tighten.
