- MEXICOWANDERERExplorerGreat Response Sir.
Copy and to Microsoft Word It Goes - darsben1ExplorerFurther update.
After the Genny was out of the Motor home It was taken to Bailey electric in Corfu. Further Testing disclosed that the ROTOR windings are bad not the STATOR as I was originally told by a local shop.
For everyone's info and after much searching the rotor in my Genny if purchased from Cummins would be about $1000.00. Rewinding is in the $400 - $450 range plus shipping
Only 2 places that I found in the U.S will bother rewinding a rotor my size
#1 Eurton Electric Co., Inc. 9920 Painter Ave Whittier CA 90605 POC [email protected]
#2Quality Armature 5259 W. Grand Ave. Chicago, IL 773.622.3951
[email protected] POC ROCCO
Hope this helps someone in the future - darsben1ExplorerThank you mexicowanderer. As soon as the stator is out of the Genny I am headed down there and I will be sure to ask that question
- MEXICOWANDERERExplorerAs a tip...
Ask them if they can vacuum varnish and bake.
What this means is, the finished windings are dipped in varnish. Then the stator assembly is immersed (along with a lot of other windings) into a big tank.
The tank is pumped down to a high state of vacuum and left for a couple of hours.
Then the stator is baked to cure the varnish.
The vacuum does an amazing job eliminating micro air bubbles in the varnish.
It doesn't only insulate
It holds the windings as a matrix. making the assembly vibration proof.
I have no idea if Onan does this as the OEM. - darsben1ExplorerNew GOOD LEAD
I have found a place named Bailey electric 2186 Main rd Corfu, NY 14036
7-5 pm (585) 599-6487. POC is named Josh.
They state they can and will rewind Onan Stators - darsben1ExplorerThank you MEXICOWANDERER I am checking them out right now.
Okay I contacted them and they do not rewind stators for 110 volt generators.
The main office in Kent referred me to the Chula Vista facility.
That facility said no. I called the main office again and spoke to someone in corporate office and they confirmed that they do not rewind stators for 110 volt generators.
Thank you for the lead any other leads are appreciated - MEXICOWANDERERExplorerProven reliability. They are the largest stator rewinders in the USA and did a 150 horsepower stator for a friend...
ROMAINE ELECTRIC - WASHINGTON
CORPORATE HEADQUARTERS
8811 S. 208th St
Kent, WA 98031
Phone - 800-426-5005
Fax - 425-264-0488
[email protected] - darsben1ExplorerI did lots of looking and have found that
http://eurtonelectric.com/
can rewind the stator.
I will update this thread as I go through the process of getting the stator rewound
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
