bsimonds's avatar
bsimonds
Onan error code 24
My Onan 7.5kw diesel generator starts and runs five minutes (load or no load) and dies with a error code 24 (Temp. sender fault). I can restart it immediately and it will again run five minutes and die. Output on each leg is 123V while running. Is there an access panel or opening where I can visually verify that the belt is OK? Where is the temp. sender and how do I access it?
  • Just as a follow-up for future searchers, Kpackpackkelley kindly PMed me the parts manual. I found and replaced the water temp.sensor and all is well!
    Thanks, Kelley!
    Bill
  • Parts manual sent
    HDKAH (Spec A?K)
    HDKAJ (Spec A?K)
    HDKAK (Spec A?K)
    HDKAT (Spec A?K)
    HDKAU (Spec A?K)
    HDKAV (Spec A?K)
    981-0200
  • Do you have your parts manual ? Look at it and you might can tell where it is by the picture.
    If you need manuals post your full model and serial number and I'll send the manuals.
