Apollo11sailor's avatar
Aug 22, 2015
Onan fuel pump or carb
My Onan 4000 model KY L with 170 hours will start and run for a couple of minutes then it dies. Acts likes it is running out of gas.
Knowing that the fuel tank was full I suspected the fuel pump. I disconnected the fuel input line from the filter and connected a short hose that I inserted into a gas container. Then pressed the Stop button to prime, worked fine. Next pressed the start switch and the unit started and ran fine for three or four minutes till I shut it down. Thinking that this confirmed that the pump was OK I put everything back together and restarted the unit. After about two minutes the unit started to sputter or surge. Did that for about 30 seconds and then died. I immediately disconnected the carb input goes and there was no fuel evident.
Is it possible that the pump has degraded and can no longer sufficiently pump fuel from the tank. It seemed to work fine when I tested direct from a container from about two feet.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 12, 2026
