Have a Onan marquess gold gen At gen just above the breaker switch there is a white switch (no toggle just slide) Was wondering if anyone knows what this slide left to right switch is? Couldn't fin...
Switch on dash should just have four plastic spring like tabs 2 on top and 2 on bottom that can be compressed to pop out of dash. Use a thin blade maybe to push them down a little from front of switch. I found a wire Diagram if you can not find one or get one from others here.
Good Luck, DJ
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
