Have a Onan marquess gold gen At gen just above the breaker switch there is a white switch (no toggle just slide) Was wondering if anyone knows what this slide left to right switch is? Couldn't fin...
If it worked one time by wiggling wires got to be a connection back up a ways and look at a little bigger picture you may see something when your real close you can only see a little part of what your working on . Have you tested for continuity from one end of wiring harness to the other one at a time you may have to have a long piece of wire tied on one end pull it to the other end then hook your mutimeter up and test for continuity if you can't find it you'll have to take it in
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
