stargirl96's avatar
stargirl96
Onan generator doesn't work
We are second owners of a 2017 Jayco Greyhawk 29ME MH. The generator worked when we bought it from a dealer, but two months later it won't turn over. It's a Onan 4000 Micro-quiet generator. When we push and hold the generator switch, we hear a series of beeps or chirps and a clicking noise from the generator. It doesn't even try and turn over. We've tried it with the house batteries turned on and off. Any ideas what's going on?
  • The Jayco 2-year warranty does not transfer to a second owner, but the Cummins/Onan warranty does. This does sound like a battery issue, but if something else is involved, you are covered by the Cummins/Onan warranty completely for 2 years and a limited warranty for the third.
    https://power.cummins.com/sites/default/files/PGBU-Warranty-Statement.pdf#page110
    There are Cummins repair shops across the U.S. Had to take ours to the one in Kenly, NC for a fuel pump replacement under warranty. Good luck.
  • Sure sounds like low battery or loose connection to battery. Get a multimeter like westend suggested and check voltage at the starter relay or starter (starter is better place, but can be hard to reach) while you are trying to crank over the genny. The "meter" on the wall is about worthless for giving you anything more than very rough battery state indication.
  • Meter says 100% for house battery and 60% for truck battery. Would the truck battery affect generator? Also, I'm hooked up to shore power now, so would this give an inaccurate voltage reading for house battery? Thanks for your advice.
  • X2 Make sure the batteries are fully charged and all cable connections are clean and tight. Can the dealer look at it?
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
