WingsFan1313's avatar
WingsFan1313
Onan Generator Hunts Under Load
Hey folks! I wanted to first offer my thanks for those of you who answered my previous post. For those of you who don't know the backstory, I bought my first motorhome (2002 Fleetwood Tioga 24d) last month. As I am not very mechanically inclined, your help has been instrumental in my getting this far; when I brought it home, the generator would not start at all and you folks got me through that, so I thank you!
Here's where I'm at now, and it has a couple of us puzzled, so I figured I would reach out to you. I'll list all the known scenarios below. The generator is an Onan 4000 Microlite KY series.
- When I run the generator with no load, on first start-up, it runs well for 15 minutes or so. Voltage tests out within spec (127 +/- 4.5). After 15 minutes with no load, it starts to sag a bit (120-125 volts).
- The generator hunts with a heavy load on it (A/C or Microwave). This happens within 2 seconds of my turning either of those items on.
- If the generator starts to hunt, and I turn off the A/C or microwave, the generator continues to hunt -- it does not go back to normal no-load operation.
- If I turn the generator off and immediately back on, 7 times out of 10, it will come back to normal no-load operation. The other 3 times, it will continue to hunt.
- I ran Seafoam/Gas mix through the generator today to clean out all the valves, nooks, and crannies. While hooked up to the external can, the generator ran with no noticeable drops with no-load (I didn't try to put a load on it while running the cleaning). It was probably the best it ever sounded. When I hooked it up to main gas, it ran as above -- well for about 5 minutes and then I could hear the tone of the generator come down a bit.
Things I have done/tried (in this order):
- Filled the main gas tank with fresh gas.
- Checked the genset engine oil
- Replaced carburetor (got the generator running -- originally wouldn't start)
- Replaced fuel filter
- Replaced air filter
- Replaced spark plug
- Ran a hose to a can of Seafoam and gasoline to clean system
- Replaced fuel line from onboard gas tank to fuel filter
I also looked into the governor issue that many people have been talking about and downloaded the service manual to properly adjust it (within my limits -- I don't have a load bank to adequately test it). The issue is -- I can't get the generator to *not* hunt long enough to make adjustments to the sensitivity screw, and once it starts hunting, no manual adjustments bring it back to normal.
I'm stumped. Any help would be greatly appreciated. Thank you in advance! :)
  • If the gen runs normally when not connected to the onboard fuel tank, I bet there is a problem with the vent on the onboard tank. try removing the fuel cap and see what happens. that seems to be the only thing you have not tried.
  • There are separate fuel pumps. The vehicle and the generator each have their own. If you suspect a fuel issue, try running with a load when using the external fuel can. I don't think the fuel is at fault. When you replaced the carburetor, did you make sure the linkages and springs all ended up in the correct holes? I seems like the governor is making too big of an adjustment and once it starts oscillating it can't stop. Try turning the sensitivity down before the next load test.
  • Since it apparently runs good when connected the external fuel supply, I would look towards the on board fuel source. Perhaps stale gas, even though you added new gas that may not be enough. Maybe a fuel pressure issue with the on board supple. I think the intank pump serves both the generator and the vehicle, and if I am correct, perhaps it is weak.
Having RV issues? Connect with others who have been in your shoes.24,314 PostsLatest Activity: Sep 06, 2025
