dougrainer
Jul 28, 2018Nomad
You did not state that you replaced or repaired the Cable from the BATTERY Neg post to a good solid clean unpainted surface ground. What is the gauge wires from the Battery to ground and the pos to the Genset? Your clue to bad/inadequate battery supply ground was the melted wire. The path of resistance attempted to go thru the furnace circuit, resulting in the melted wire. Doug
