Update: Not sure if this is the problem, but the Manual talked about a Fuel solenoid that has a fuel shut off valve so husband undid the screw from the carb. and gas poured out. So he ordered a new solenoid and fuel filter.
It will take a few days to get here. If we are lucky we will be cooled down again. I tried to see the hours on Genset but it will not light up I guess unless Gen is running. And I am a bit confused Kelley are you talking about the house battery which is under the step or a battery on the Generator? I did not know there was a battery on the Generator?
Again
Thank you all
