Peg61's avatar
Peg61
Onan Generator Stopped running
Hello, We are in very hot South Texas and we plug into a large company Generator for most of the day but in the afternoon our 30 am plug in shore line, will not run both air while plugged into that Generator. plug and cord over heats.
So we will unplug and turn on our onboard Generator which is an Onan and run it for about 2 to three hrs. to cool down in the hot part of the early evening. Yesterday the Gen died after an hour and my husband check it was low on oil so he took care of that, now the Gen will turn over chug a few times then die. He has check the fuel filter and fuel pump, can see it getting fuel. He has now gone to town to try to figure out what else to try: Any one out there have this problem?
Thanks for any help
Peg
  • Handbasket
    Hand basket your half way through this after I post information. Why jump in with no help now. I do not understand people that just want to rant.
    Now on with the show.
    My husband tried to take off the Carb could not get it off but sprayed it and tinkered with it needle is clear. He checked all hoses they are ok just not sure what is left but to call someone thanks you all very much for all the help Kelley thank you for the number we are down by Big Wells Tx which is not very big. lol. Checking wires but if wires were bad I did not think it would turn over . KG I will check out that site maybe they will give us an idea?
    back to drawing board thanks
  • Peg61 wrote:
    Handbasket
    Hand basket your half way through this after I post information. Why jump in with no help now. I do not understand people that just want to rant. .....
    And you apparently missed that fact that the 'rant' was to the moderators, not you.
  • No real familiar with this model. Does it have a belt that drives the generator end? If so, check the belt for damage
  • j-d's avatar
    j-d
    Explorer II
    Peg, Did you get a service manual for your specific genset? If you did, it should contain a description of how the sensor works, and a wiring diagram showing how it connects. Armed with that information, you should be able to bypass it. IF, of course, that spec code has one...
  • Peg61 wrote:
    How do I bypass the oil sensor?
    Not familiar with your setup - have read some threads where people just disconnect wire to sensor and ground it - might be worth a shot.
  • It's so much easier to take a Honda generator that is portable to an easily available shop, than futz around with an Onan mounted on board, so it seems.
    I doubt many who own an on board generator have ever considered trading it in for a portable. Most issues are a result of lack of use and Onan's tend to last forever with nominal maintenance - common problem tends to be associated with not using them enough. As far as finding someone to fix .. same guys who work on portables can fix an on board and any truck outfit will have someone experienced with generators (all the refrigerated trucks have generators).
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 19, 2025
