Hello I have an Onan 10,000 watt generator in my 2008 Monoco Camelot how long should it take to change the oil and all the filters ( oil gas and air ) ? and what should it cost about ? Thank You
You'd probably get a better answer in the class A forum.
I would think a fair bit of the answer depends on how readily the particular generator installation allows for access to the generator. Changing the oil and filters in itself shouldn't be an overly long or complex process. I probably wouldn't bother with the fuel filter unless there was some reason to believe that it was in need of replacement, such as the generator giving signs of fuel starvation under load.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
