Hello I have an Onan 10,000 watt generator in my 2008 Monoco Camelot how long should it take to change the oil and all the filters ( oil gas and air ) ? and what should it cost about ? Thank You
A shop that is familiar with these generators, and is set up correctly should be able to change the oil and oil filter in about 15 min. air filter another 15 min, as the coolant overflow tank has to be removed for access to air cleaner housing. Fuel filter is a little trickier, as some fuel system bleeding/priming is required. overall should be able to do in an hour, including clean up. Oil and filter about $50, air and fuel filters about $25 each (Onan list prices)
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
