ppuck17's avatar
ppuck17
Onan generators
Is there a significant difference between the 5.5 and 7?
Thanks,
Preston
❚ Did you see the "Announcement : ★★READ BEFORE POSTING HERE★★"?
    Forum Posting Help and Support is reserved for questions related to posting issues with Open Roads Forum sites, member profile and photo testing, and for reporting account issues. Please avoid using this forum for RV related questions, as doing so can delay responses to your thread. Instead, select the Sub-Forum which corresponds to the subject of your topic. Thank-you!
Moved from FORUM POSTING HELP AND SUPPORT
  • 5.5 is a lot of generator a 7. 0 is a whole lot of generator. What all do you want to run ?
  • IIf you are referring to Onan RV generators, they are very similiar.
    The 7kw runs at a little higher rpm to make enough horsepower to pull 7000watts.so they use different drive belts and gen pulleys. It also has a larger rotor and stator in gen end. The circuit breakers are usually different also, as 5500 normally has a 30a and 20a breaker, where the 7000 has 2 50a c/b's. the engines and all the mounting base and enclosure are same.
  • 1500 watts or about 12.5 amps. The larger unit will use a little more fuel.
    What do you plan to run with the generator? If you give us a little more info maybe we can give you a better answer.
    I have a 5000 watt generator in our Southwind, it does everything I need.
    If the price difference wasn't too much, I would go with the larger generator. But it depends on what you are running with the generator, how long and how often.
    Welcome to the forum.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
